Can i add mAX W130 as a 3rd satellite to W121 Kit - Two W21
  • February 23, 2025
  • 163 views
Hi,
I have the following Arris Setup:
Modem : S33
Wifi Router : W121 Kit - Two W21 routers - SURFboard mAX Mesh Wi-Fi 6 system - AX6600 Speeds.
Will I be able to add one W130 as a 3rd wifi router to boost speed and performance ? will the 3 be compatible ? any ideas please ?
Thank you !!
Unfortunately, it’s not possible to add the W130 with the W121 Kit, as the W130 is a different model with a distinct configuration during onboarding.
Please note that the W21 uses Wi-Fi connection during onboarding, whereas the W30/31 models uses Bluetooth connection during onboarding.
To ensure full compatibility, I would recommend getting a W21 single pack, which can be seamlessly integrated with your existing W121 kit.
  • March 1, 2025
Hi Thank you for the response.
Just to double confirm, I already have two W21 Devices (Main router) and Satellite Router. So I will be able to add the third W21 and all 3 will be compatible  ?
Thanks again in advance
Yes, ​@Balakc , with the existing W121 mesh, you can add one more W21 as a satellite to the system.
Note: The total system would consist of three routers, meaning you can add one main router and two satellites to the W21 series. This also applies to the mAX Plus W30 and mAX Pro W31 models.
  • March 2, 2025
Thank you so much for your response. appreciate it.
