Hi,
I have the following Arris Setup:
Modem : S33
Wifi Router : W121 Kit - Two W21 routers - SURFboard mAX Mesh Wi-Fi 6 system - AX6600 Speeds.
Will I be able to add one W130 as a 3rd wifi router to boost speed and performance ? will the 3 be compatible ? any ideas please ?
Thank you !!
Unfortunately, it’s not possible to add the W130 with the W121 Kit, as the W130 is a different model with a distinct configuration during onboarding.
Please note that the W21 uses Wi-Fi connection during onboarding, whereas the W30/31 models uses Bluetooth connection during onboarding.
To ensure full compatibility, I would recommend getting a W21 single pack, which can be seamlessly integrated with your existing W121 kit.
