AX6600 W121 and AX6600 W21 Compatibility
I want to add another AX6600 to my network.  I currently have (2) AX 6600 W121.  Will a AX6600 W21 work with the other AC6600 W121s
thank you
Hello wallynvicki
                             W121 is compatible with W21, so you can add W21 with W121’s by following steps mentioned on the article below on the surfboard central application.
                              http://arris.force.com/consumers/articles/General_FAQs/mAX-W21-Add-Additional-mAX-Satellite
Let us know if this helps.
Hello wallynvicki
  • July 7, 2023
Thanks
