Change and expand mesh system
  • August 7, 2023
  • 57 views
Have W33 Modem with W21 Router and W11 satellite. Need to expand coverage. P:urchased set of W121s. Do I need to replace W21 with W121 as primary router, remove W11 and add W121 and W21 as satellites or can I just add W121s as satellites to W21?
Best answer by Netopia
You can have up to 3 max units in a mesh network, 3 W21’s or 2 W21 + W11.
Return the W121 and buy a W21 to add to your current setup.
Forum|alt.badge.img+30
  • Rockstar!
  • 274 replies
  • August 8, 2023
