Satellite not connecting in W21
w21 satellite not connecting says loading. I preformed a reset and it’s still flashing green and white.
Since you are unable to add satellite in SBC application,  I suggest you to reset the satellite and try to add it again.
Please find the link given below:
http://arris.force.com/consumers/articles/General_FAQs/mAX-Routers-Factory-Reset
Also make sure that the satellite is next to main router.
  • 2275 replies
  • October 23, 2023
did you reboot the primary router?
Try hardwiring in the satellite (temporarily)?
  • October 23, 2023
I’ve tried both and I’m still getting the green and white leds.
