Switch for S33 - W21 setup
  • 4 March 2024
  • 6 replies
  • 42 views
Badge +1
Need a 5 port switch for S33 - W21 setup. Recommendations?
Best answer by plemans 4 March 2024, 18:55
Userlevel 6
Badge +40
Pretty much any unmanaged gigabit switches will work fine.
Just make sure to attach the switch to the w21 and not to the modem.
Badge +1
Thank you. Good to know not to connect to modem as that was my plan.
Badge +1
Ok I'm home now. Do I connect S33 to WAN port on W21? Then LAN port on Same W21 to switch. Do I need to change anything in Surfboard Central app?
Userlevel 6
Badge +40
Yes. That's how you do it. Shouldn't need to change anything if you have an unmanaged switch
Badge +1
All connected and working well. Thanks for your help. 😊
Userlevel 6
Badge +40
Glad its working!
