W161 Unable to access web GUI
  • November 23, 2023
  • 122 views
Hello, I just set up my new 6E system but need to do further configuration through the web GUI. There is no clear way to access it, how should I?
  • 2275 replies
  • November 23, 2023
I don’t think it has a gui and is only app managed through the surfboard app. Unless something has changed recently
  • November 23, 2023
It does, I am able to access the gui thru the ip address of the node.
  • 2275 replies
  • November 24, 2023
I don’t have the W161 to check it so I have to go over what others have said and the review from dong knows states it doesn’t have a gui, only app access.
https://dongknows.com/commscope-surfboard-max-6e-mesh-system-review/
The W31 I’d use prior didn’t have gui access either.
maybe @SURFboard Moderator can help
