After doing a factory reset on my modem , im unable to access my admin control panel to rename my network . I type in the ip address with no luck.
What device do you have?
What ip address are you using?
if its a modem, did you try 192.168.100.1?
Arris , 192.168.0.1 yes I did. No luck
I tried it with modem hooked up to internet and unhooked as well. Now a message appears saying unsupported protocol.
try a Hard wire connection to the modem, mine responds to 10.0.0.1
I am having the exact same issue. Prior to doing a reset, my router had “unknown” clients showing and my settings were screwed up. It took several attempts for the reset to hold, using the 30-30-30 method, but now my configuration is showing a router IP address other than 192.168.0.1. It is showing 104.173.64.1 instead.
