Difference between the options "restart router" and "reboot device".
  • August 1, 2022
  • 349 views
I would like to know what is the difference between these two options, because they appear to make the same function.
Is this on a combo device? You don’t put which one you have.
If its a combo device, it might just be the internal router restarting while leaving the modem active. Versus the other doing a full reboot on both.
  • 2275 replies
  • August 2, 2022
