Internet Modem without WiFi
  • November 5, 2024
  • 9 replies
  • 97 views
I have my set-up with Arris (my old unit), Netgear WiFi 7 Router and Ooma Phone.  I need to upgrade my Internet Modem to allow for the Ooma Phone, which is hooked up to my Netgear.  Which Arris Modem would work for my set-up?
Ooma phone is not compatible with Arris's modem/router.
  • November 5, 2024
Thank you for your reply.
  • 2253 replies
  • November 6, 2024
Ooma is a voip protocol that directly connects to the router and not the modem. So you should be fine with any modem.
Who’s your ISP and what speed plan are you paying for? that’ll be the key questions
  • November 6, 2024
I have Comcast/Xfinity for my internet.  I just want to upgrade my Internet Modem.
Arris has updated models such as G34, G36, G54, G18 and G20. These are the models which is the combination of modem and router.
Cable modems: SB8200, S33 and S34.
Could you let us know the product’s model number which you are using currently?
  • November 6, 2024
I think it says SB 6183
  • 2253 replies
  • November 7, 2024
I’d look at the Arris S34, Netgear CM3000, or Coda56
Those are all the multigig devices that are modem only.
https://assets.xfinity.com/assets/dotcom/projects/cix-4997_compatible-devices/2024.08.14%20Full%20List%20of%20Compatible%20Devices.pdf
There are modem/router combo devices. And there’s lower models such as the Netgear CM2500 that aren’t multigig. But if you follow the list for the “next gen tier” you’ll be able to either have the increased upload speeds or be covered when that area gets the upgrade.
  • November 7, 2024
Thank you, I’ll check those out.
  • 2253 replies
  • November 7, 2024
good luck!
