Need to cancel order
  • February 6, 2025
  • 95 views
Hello,
I need to cancel an order I placed.
Also, it is ridiculous that I have to make a forum post to get support. The support site only allows you to use the contact methods if you have the serial number. I obviously don’t have the serial number because I don’t have the product and don’t want to receive the product. There should be a support number on my order page to get support for the order I placed.
usually the fastest way is to contact support. Did you try calling in?
Could you share the order number to check on this further?
  • February 6, 2025
Order ID is 60661. Thank you for the assistance
  • February 7, 2025
