In Australia,we “Have to use”, your CM8200B, Cable Modem, which we are not allowed access to. ie,no possibility,of improving performance. I, for 1, find this un-acceptable! Any idea’s, onhow to fix this problem?
Possibly,not supported?
The firmware is controlled by the ISP on modems. Its part of the docsis spec. Otherwise users could modify the firmware to whatever speed package they choose versus what they pay for. If they’ve locked it down so you don’t have access, there isn’t anything for the user to change.
Eitherway, a modem only device doesn’t have anything to change on it. It just allows you to view connection strengths to test the connection/view the logs.
What do you think you’d change or think will make it better?
