Answer
modem makes high pitch sound on S33
  • July 18, 2024
  • 564 views
This is an ARRIS Surfboard S33 DOCSIS 3.1 I purchased about a year ago. It is under warranty still. The pitch makes it impossible to work in the room. I am requesting a replacement. Thanks.
In this to work on this further we would suggest you to reach out to Arris.com/consumersupport if the modem is under warranty.
