s33 eero 6+ not connecting
  • August 16, 2023
  • 398 views
I have Att at home and xfinity
xfinity to eero won’t connect but Att does
Great, so your Internet service provider is Xfinity and internet works fine and you have router connected to S33 so make sure the setup is perfect and monitor connection if any issue on modem reach out to Arris.com/consumersupport
As you had mentioned two Internet Service Providers which is Atandt and Xfinity at your place. Usually only one Internet Service Provider is required to activate the modem so please provide us more information to guide you further.
  • August 20, 2023
S33 is connected to xfinity not Att
after like 3 hard resets
multiple power cycles eero and xfinity s3 worked
