S33 power cord
  • July 31, 2023
  • 1221 views
This is a very basic question. I had stored my S33 when moving and the power cord that was near it (however not sure which power cord is correct), is branded as APD model # W8-18R12FU (asian power devices). Was this the one that came with the unit?
The power cord that is recommended to be used with the S33 is an UpBright 12V AC/DC Adapter (12VDC 1.5A 18W).
If you are unable to locate the power cord, you could always shop for the same on Amazon.
Below is the link for the appropriate cord :
https://www.amazon.com/Arris-Surfboard-S33-Power-Supply/dp/B09QM8S6R7
