S33 showing solid white light, what does this mean?
  • January 6, 2025
  • 103 views
We recently started a home project and needed to cut the power off from the breaker. The router/mesh system were both plugged in when we flipped the breaker to turn off the power. Once we flipped the breaker back on, the router now shows a solid white light. There’s nothing in the owners manual depicting what a white light means. If it’s useful information, we use a deco mesh system (AX3000) that is currently showing red, which indicates it cannot connect to the WiFi. How do I get my WiFi working again?? I’ve tried: resetting the router (unplugging, pressing little reset button on the bottom), resetting the mesh system, replacing the power cord, and nothing works.
Since the LED light on the modem is solid white, could you try connecting a computer or laptop directly via an Ethernet cable to access the internet?
