SB6183 modem help.
  • December 17, 2022
  • 510 views
Good morning everyone,
I’ve been having my internet drop randomly and more frequently now, I have been trying to figure out what’s causing this issues, I have checked my router and went through them to see if it was them, but it doesn’t seem like it. So now I’m checking my modem.
Here is my event log, sorry if its long. I’m just trying to figure out what all this means. I’m assuming this is what’s causing my internet to drop all of a sudden then come back?
My ISP is Xfinity, if there is anything else I can post that can help solve this issue please let me know.
Thank you,
Sun Nov 20 16:00:03 2022 Critical (3) No Ranging Response received - T3 time-out
Sun Nov 20 16:19:29 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out
Sun Nov 20 16:20:06 2022 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing
Sun Nov 20 16:20:13 2022 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing
Sun Nov 20 16:20:26 2022 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing
Sun Nov 20 16:20:34 2022 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing;
Sun Nov 20 16:20:39 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out
Sun Nov 20 16:21:16 2022 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing
Sun Nov 20 16:21:23 2022 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing
Sun Nov 20 16:22:16 2022 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing
Sun Nov 20 16:23:18 2022 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
Sun Nov 20 16:30:21 2022 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
Sun Nov 20 16:30:53 2022 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
Sun Nov 20 16:31:29 2022 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
Mon Nov 21 10:36:43 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-ou
Mon Nov 28 08:56:18 2022 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
Mon Nov 28 08:56:25 2022 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
Mon Nov 28 08:57:13 2022 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
Mon Nov 28 08:57:13 2022 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
Mon Nov 28 08:57:33 2022 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
Mon Nov 28 08:57:33 2022 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
Mon Nov 28 08:57:54 2022 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
Mon Nov 28 08:57:54 2022 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
Mon Nov 28 08:58:03 2022 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
Mon Nov 28 08:58:04 2022 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing
Mon Nov 28 08:58:13 2022 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time ou
Time Not Established Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out
Time Not Established Critical (3) No Ranging Response received - T3 time-out
Thu Dec 08 13:20:39 2022 Critical (3) REG RSP not received
Sat Dec 10 12:27:24 2022 Critical (3) REG RSP not received
Time Not Established Critical (3) No Maintenance Broadcasts for Ranging opportunities received - T2 time-out
Fri Dec 16 20:40:28 2022 Critical (3) REG RSP not received
Fri Dec 16 20:41:50 2022 Critical (3) Unicast Ranging Received Abort Response - Re-initializing
Fri Dec 16 20:41:55 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out
Fri Dec 16 20:42:23 2022 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
Fri Dec 16 20:42:54 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out
Fri Dec 16 20:43:27 2022 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
Fri Dec 16 20:43:42 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out
Fri Dec 16 20:43:59 2022 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
Fri Dec 16 20:51:14 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out
Fri Dec 16 20:51:14 2022 Critical (3) Unicast Ranging Received Abort Response - Re-initializing
Fri Dec 16 20:51:29 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out
Fri Dec 16 20:51:35 2022 Critical (3) Unicast Ranging Received Abort Response - Re-initializing
Fri Dec 16 20:51:53 2022 Critical (3) No Ranging Response received - T3 time-out
Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;
Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC framing
Fri Dec 16 21:00:50 2022 Critical (3) REG RSP not received
Fri Dec 16 21:22:14 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out
Fri Dec 16 21:22:14 2022 Critical (3) Unicast Ranging Received Abort Response - Re-initializing
Fri Dec 16 21:22:17 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out
Fri Dec 16 21:22:47 2022 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
Fri Dec 16 21:29:59 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;
Fri Dec 16 21:33:32 2022 Critical (3) Resetting the cable modem due to docsDevResetNow
Fri Dec 16 21:34:50 2022 Critical (3) REG RSP not received
Fri Dec 16 21:36:03 2022 Critical (3) Resetting the cable modem due to docsDevResetNow
Fri Dec 16 22:12:59 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;
Fri Dec 16 22:13:19 2022 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC
Fri Dec 16 22:13:24 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out
Fri Dec 16 22:14:57 2022 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
Fri Dec 16 22:38:22 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out
Sat Dec 17 00:04:57 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out
Sat Dec 17 00:05:29 2022 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC
Sat Dec 17 00:05:43 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out
Sat Dec 17 00:06:02 2022 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
Sat Dec 17 00:16:52 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;
Sat Dec 17 00:16:52 2022 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted
Sat Dec 17 00:16:52 2022 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 0
Sat Dec 17 00:17:32 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out
Sat Dec 17 00:17:32 2022 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted
Sat Dec 17 00:17:32 2022 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 1
Sat Dec 17 00:28:39 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;
Sat Dec 17 00:30:51 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out
Sat Dec 17 00:30:51 2022 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted
Sat Dec 17 00:30:51 2022 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 0
Sat Dec 17 00:31:53 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out
Sat Dec 17 03:40:32 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out
Sat Dec 17 06:59:00 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out
Sat Dec 17 07:05:43 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out
Sat Dec 17 08:05:14 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out
Sat Dec 17 08:05:34 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out
Sat Dec 17 08:06:42 2022 Critical (3) Resetting the cable modem due to docsDevResetNow
Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv6
Time Not Established Warning (5) ToD request sent - No Response received
Sat Dec 17 08:07:45 2022 Critical (3) REG RSP not received
Sat Dec 17 08:25:55 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;
Sat Dec 17 08:25:55 2022 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted
Sat Dec 17 08:25:55 2022 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 1;;
Sat Dec 17 08:27:15 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out
Sat Dec 17 08:27:55 2022 Warning (5) Dynamic Range Window violation
Sat Dec 17 08:30:03 2022 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out
Sat Dec 17 08:30:22 2022 Warning (5) Dynamic Range Window violation
Hello Zephyl,
I apologize for the inconvenience. that you are facing with your modem, the logs are Values read by technicians from the internet provider end, since the logs are what the coaxial cable transmits and the log screen on the router is the translator so can be easily read by them, the coaxial cable is owned by the Internet service provider.so sorry not sure about the event log
If your Event Log is reporting a high volume of errors, this would indicate a potential CMTS signal issue. To troubleshoot these errors, we would like to note the cable signal levels being used by your (Modem).
Please follow the below mentioned link to check cable signal levels:
.http://arris.force.com/consumers/articles/General_FAQs/SB6183-Cable-Signal-Levels
Let us know if this helps .
