How can I split the 2.4 and 5ghz networks?
  • January 3, 2023
  • 3573 views
Hi!
I have a Arris SB6190 cable modem and I use Google Mesh Network.  I have a new device that requires 2.4ghz.  How can I “split” the 2.4 and 5ghz signals so that my device would stay connected on the 2.4ghz signal?
Please advise, I look forward to hearing from you soon!  Thanks!
Best answer by HGilliland
Hi Everyone!
Thanks to plemans’s response, that helped me find the solution without needing to contact Google.  I did some quick researching and learned that Google’s Nest WiFi does not allow you to split bands. You can often get around this issue by creating a guest network, which only operates on the 2.4-GHz band.
So, with that information, I created a guest network and was able to operate the devices using the 2.4-Ghz band.  Problem solved!
Thanks to everyone!  :-)
  • 2277 replies
  • January 4, 2023
The SB6190 is a modem only device. It has zero wireless capability.
You can ask google about how to do that on their mesh product.
  • January 5, 2023
Thanks!  I’ll contact Google for assistance with this.
  • January 5, 2023
Hi Everyone!
