Solid Green Transmit Light on SB6190
  • February 28, 2023
  • 216 views
CapriciaDonka
The Many
The transmit light, which should be solid blue to indicate bonding, is solid green.  I cannot find a reference to what this means with respects to the transmit/receive lights.
Please advise.
Usually means only 1 channel is connected and your speeds are limited. Channel bonding allows multiple channels to be “bonded” together for faster speeds/performance.
  • 2275 replies
  • February 28, 2023
Are you talking the “send” icon?
If so, when its green, it means non-bonded upstream channel is connected.
You can find it in the manual here.
https://arris.my.salesforce-sites.com/consumers/ConsumerProductDetail?p=a0ha000000REMs8AAH#panel3
CapriciaDonka
The Many
Thank you.
What does it mean when we have a connected non-bonded channel?
  • 2275 replies
  • February 28, 2023
