hi, I just recently purchased and installed this device. It works fine, I mean I can navigate through the internet flawlessly. But I’m having this behavior on my unit, the first light which I think is power is on and white same as the fourth light, the other 2 are blue. Based on the manual of my modem the lights should be either green or blue. Does that mean my modem is faulty?
Unexpected behavior (lights) sb6190
Best answer by Siuu1994
Hello
Hope this info finds you well,
The LED behavior you are describing is complete normal and the explanation is the colors of the LEDs, the blue LEDs are too bright and they dim the color of the others one, this articule of Arris can help you out, Your modem is not faulty and is operating just fine,
Siuu1994
