Have done a power reset and a factory reset but still just power light comes on.
Do you have a coax connected to it?
Did you try it with it disconnected?
Also check the power supply, I’ve seen the wrong supply used before
Have tried it with coax and router cables connected and unconnected . Power supply the correct one, has been working for 2 years with it and i verified voltage output correct with a VOM
