After Power outage, internet connection drops intermittently on SB8200
We had a brief power outage to our home over night. When trying to connect to the internet in the morning, we had no connection, or intermittent connections. I rebooted the SP8200 and also did a reset. I contacted our provider, Breezeline, who said there were no outages in the area. They trying to reset the connect from their end twice. The connection would come back briefly and then fail.
Finally the provider eventually said that it was the modem, and that I had to contact the manufacturer, Arris, to determine the problem. This is where we stand at the moment.
  • 2277 replies
  • April 17, 2023
Do you have a copy of the cable connections page and the event logs from the SB8200?
  • April 17, 2023
  • April 17, 2023
  • 2277 replies
  • April 17, 2023
Your power levels are out of spec and you have a ton of errors in the lines.
Your isp will need to check it
  • April 17, 2023
I sent two connection pages that were downloaded a few minutes apart.
  • April 17, 2023
Thanks, I will get back to the ISP, even though they assured me that the trouble was with the SB8200. It seems kind of odd that it would work so well for so long, and then just quit.
  • April 24, 2023
The modem must have been fried, because I bought a new one and had it provisioned for Breezeline. It works fine. The new modem is version 7, and the first one had no version #, so it must have been version #1. Thanks
  • 2277 replies
  • April 25, 2023
Tough to tell if its an internal hardware failure of line issue because the logs/connections will both look poorly if something on the internal coax part failed/broke.
but glad you got it sorted!
