Arris Surfboard SB8200 Making Constant Ringing Sound
  • December 11, 2024
  • 252 views
My modem won’t stop making a ringing sound when on. This started around a year after first using the modem.
If the problem persists after checking with different power outlets and power cords, I would suggest visiting www.arris.com/consumersupport for further assistance.
  • 2324 replies
  • December 11, 2024
Is it in warranty? If so, contact support. If not, try a different power supply for it. usually its a capacitor in the power supply
