Downstream led Light Flashing (SB8200)
  • November 3, 2023
  • 1972 views
For seemingly no reason my SB8200’s DS light started flashing. There are no reported outages in my area, no cables have been moved, shifted or otherwise touched. I spoke with my ISP and they advised that my modem was not able to be detected. Any suggestions ?
We understand that one of the LED lights (Receive which is the downstream channel  ) is flashing shows that modem is not receiving proper cable signals from you’re Internet Service Provider(ISP) . Possibly  connect modem directly to a computer (either windows or Mac) , if not possible of not having a direct connection try connecting to Wi-Fi of the Router  and login.to GUI of the modem (192.168.100.1) and check the cable signals with the below link:
If the signals are not within the acceptable range contact you’re  Internet Service Provider(ISP) and do a Re-Provision if still the Receive light is flashing ask them to check the cable lines.
Also check if all the other lights are solid green .
  • 2277 replies
  • November 3, 2023
Got a screensnip of the cable connections page?
You can check your lines but usually it means something in the line isn’t connecting back to the ISP.
They usually have to check it.
I don’t have a screen shot, but I tried replacing all of the coax cables between the modem and the entry point to the house and nothing changed.
  • 2277 replies
  • November 3, 2023
then you’re probably down to them having to check it (the isp)
