SB8200 Comcast/Xfinity slow speed internet Issues
  • November 29, 2024
  • 9 replies
  • 114 views
**** Excuse the SN8200 in the title *****  Moderator can you fix please? ****
I had a T25 VOIP modem but dropped VOIP and the T25 was only functioning at maybe 75% of an advertized connection of 500 generally much less maybe 275 or less. This SB8200 doesn’t seem to perform much better or maybe worse from time to time. These are images from a 3 hour fresh Comcast/Xfinity connection and I have used the ‘reset’ depress on it. Channels 33 and 34 interest me. The channels that aren’t in  the image are similar to what’s in those that can be seen. What about the errors on boot that I see?
Channel 33 on a fresh boot was 3.7dBmV  40.5dB 123553490  519
The table below contains the log of events that the SB8200 has detected. This log can be important to the service provider to help diagnose and correct problems, if any should occur.
Time
Priority
Description
11-29-2024, 15:40:38
Critical(3)
Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC= ( edit personal details) :bd;CMTS-MAC= ( edit personal details);CM-QOS=1.1;CM-VER=3.1;
11-29-2024, 12:9:50
Notice(6)
CM-STATUS message sent. Event Type Code: 24; Chan ID: 33 ;CM-MAC Addr: N/A; OFDM/OFDMA Profile ID: 3 ;CM-MAC= ( edit personal details) :bd;CMTS- ;CM-QOS=1.1;CM-VER=3.1;
11-29-2024, 12:9:35
Notice(6)
CM-STATUS message sent. Event Type Code: 22; Chan ID: 33 ;CM-MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A;CM-MAC= ( edit personal details) :bd;CMTS-CM-QOS=1.1;CM-VER=3.1;
11-29-2024, 12:9:2
Notice(6)
CM-STATUS message sent. Event Type Code: 20; Chan ID: 33 ;CM-MAC Addr: N/A; OFDM/OFDMA Profile ID: 3 ;CM-MAC= ( edit personal details) :bd;CMTS- CM-QOS=1.1;CM-VER=3.1;
11-29-2024, 12:8:59
Notice(6)
CM-STATUS message sent. Event Type Code: 16; Chan ID: 33 ;CM-MAC Addr: N/A; OFDM/OFDMA Profile ID: 3 ;CM-MAC= ( edit personal details) :bd;CMTS-CM-QOS=1.1;CM-VER=3.1;
11-29-2024, 12:8:58
Error(4)
SW upgrade Failed after download - Incompatible SW file
11-29-2024, 12:8:55
Notice(6)
SW Download INIT - Via Config file d11_m_sb8200_fast_c01m
11-29-2024, 12:8:42
Notice(6)
DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3 ;CM-MAC= ( edit personal information ) CM-QOS=1.1;CM-VER=3.1;
1-1-1970, 0:0:30
Notice(6)
Honoring MDD; IP provisioning mode = IPv6
  • November 30, 2024
I see one image has been dropped and I see no way to access/edit my original post so I’ll insert the channels image that concerned me, In this image 33 & 34 concerned me. In my original post I mentioned what channel 33 was on an original boot. The original boot for channel 33 was this:
  • December 2, 2024
you have errors in the line and the logs.
  • December 2, 2024
I have this distribution box supplied by Comcast/Xfinity and to the box is orange coax same as buried from pole to box by Comcast/Xfinity and a 10’ run from distribution box to the modem. I have 4 CableCARDS also. You’re suggesting a direct connect to the orange coax for a test? Is the distribution box a concern and I should maybe use just a splitter array for distribution?   Are there concerns other than Channel 33 & 34?
Also a new ‘EVENTS LOG’ !
  • December 2, 2024
Try it with the direct connection.
If everything worse fine, then go
INcoming line------Dual splitter-------to amplifier and other devices
                                Modem
Have the modem on its own-unamplified line. have the tv’s on the amplified leg of it.
  • December 2, 2024
                                Modem
Thank you. If it’s better direct connected, then just add a 2 way digital splitter before the distribution block? A 54-1675MHz MoCA 2.5 that’s -4dB on each leg would be OK?
  • December 2, 2024
the sb8200 doesn’t use moca. Keep it simple. Use the most basic dual splitter off the main leg to reduce signal reduction and interference. then one leg to the amp/moca and the other to the modem.
  • December 2, 2024
I have a very old Genisis 5-1002MHz -110dB RFI -3.5dB legs. Is that sufficient? You mention your CM3000 modem but for my 500 or 800 Service would a CM1200 maybe be a better choice than the SB8200 if my errors continue?
  • December 2, 2024
The genisis should be fine. Give it a shot. You can direct connect it first and see if the modem works fine and redo your connections page (after using it for a bit)
  • December 2, 2024
With splitter installed as you mentioned, PC directly to modem channels 33 & 34 are still like previous images.
This is a new EVENTS LOG. What do those events signify?
Is a solution maybe to pick up a Comcast Gateway for just testing before I have them make a house call?
Speedtest.net was 286 for a 500 provisioned plan. Speedtest.comcast.com ‘Rocket’ was similar but never 300+. I’m charged and Comcast insists I’m provisioned for 500.
*** The splitter seems to have helped my TiVo’s. They were maxing out(100+) and the -3.5 dB on the splitter took them to low 90’s. That I understand is a desired.
