I have the SBG10 router, and was wondering if i can use ethernet and wifi at the same time? Ethernet to my computer, and wifi for my Firestick?
Can wifi and ethernet be used at the same time for different devices in SBG10
SBG10 is a gateway which is the combination of modem and router so you can use direct connection and also WIFI at the same time.
