How to connect HDMI connecter with ARRIS SBG10
  • October 1, 2024
  • 47 views
Is there a way to connect this SBG10 model with a hdmi connector to a flat screen tv?
On SBG10 modem there is no option to connect to the HDMI connector. SBG10 only has the ethernet port to connect any device to it directly so if you have any adaptor that has port to connect the HDMI you can connect to the modem and use it.
