Router will not remember name of static client
  • January 28, 2023
  • 26 views
my SBG6950AC2 will not use the name of the client.  It shows as unknown, whether it is static or not.. It ignores the name put in for static, but the static IP works, just shows unknown
Hello STS,
We understand that on sbg6950AC2 the client name shows as Unknown .  Please try doing a reset and check again
To do the reset , follow the below mentioned link:
Let us know if you have any more queries on the same
