admin password issue
I just installed my new Surfboard 7600 and all is working fine and the app works fine.  During the setup process the app generated a complex password for the admin user which I have a copy of.
However when I go to the web interface and try to login as the admin user it says that either the password is bad or there were too many failed logins.
How do I get the web interface login to admin to work?
Thanks
Best answer by bobstoller
Thank you for the suggestion, but neither of those work.    I am afraid I am going to have to do a factory reset and try and set it up again.    The surfboard app shows me what the admin password is supposed to be, but it doesnโ€™t work.
  • 2287 replies
  • May 22, 2023
did you try the default ones? Try the last 8 of the serial and/or just โ€œpasswordโ€ (all lower case)
  • May 23, 2023
