Arris SBG7400ac2 in bridge mode
  • July 27, 2024
  • 195 views
I am trying to use my Arris modem/router as a bridge in a separate location.  My primary router is a Netgear C6300.  I cannot seem to wirelessly connect the two so the Arris passes along my wireless network from the C6300.  I have tried WPS initiated from both devices using the WPB wireless push button and Pin method.  No success.  It is very difficult looking up solutions on line.  Some suggest to go into the web manager and enter the SSID and password of the network.  Arris web manager does not accommodate that or at least I have not found it.  Last ditch effort before the Arris goes in the recycle bin.  Thanks for any help.
In this case for clear understanding Bridge mode will disable wifi on the modem and the SBG7400ac2 will be working as just a cable modem without wifi so only from the main router connected to the modem you can access the wifi any configuration for wifi can be done only on the router page. So to help you on this further could you please provide the right information on what you are exactly looking for on Arris modem?
