Password Reset for SBG6950AC2
  • December 6, 2023
  • 214 views
I’m locked out of SBG6950AC2.  I want to set a new password.  How can I do this?
If you are trying to login to the modem interface you need to perform hard reset on the modem then login to the modem interface using default login credentials and that will allow you to change the default WIFI credentials.
http://arris.force.com/consumers/articles/General_FAQs/SBG6950AC2-Web-Manager-Access
http://arris.force.com/consumers/articles/General_FAQs/SBG6950AC2-Changing-the-Default-Wi-Fi-Name-Password
