SBG7600AC2 connecion need
I am having problem setting the uint up for use for internet  I did do  manually set up but it didnt work still getting connection needed message
Have you reached you’re ISP for the activation or tried for self activation  Is the modem is setup now ?
  • 2268 replies
  • November 25, 2023
did you check with your ISP?
I have  xfinity  I’m trying to get my surfboard set up so I can get ride of centry link
