5G not working on Surfboard sbg8300
  • October 20, 2024
  • 72 views
I was having connection issues on my Arris SBG8300 using 5G. I enabled band steering, and now the 5G channel doesn't even show up as an option.
band steering combines the 2.4ghz band and the 5ghz band into one and allows devices to roam between them as needed
  • 2287 replies
  • October 22, 2024
