Changing guest passwords for SBG8300 Access
  • August 8, 2024
  • 131 views
I can’t login using the password that I just created when I did a hard reset to get to the pages to change my guest wifi passwords for security purposes. I have an Arris SBG8300
I did two hard resets now to try to solve it and it skips the username creation item and goes straight to the create a password and reenter password page which I completed. I then changed the name and passwords of my primary daily Wifis - but to access the guest wifi band pages - I need to login using the account info...On that side, it’s saying that I’m putting incorrect credentials (“admin” and my new password). I tried the new password from the initial steps, the new primary daily wifi password, and the number password on the back of router, I tried resetting the router again and doing it all again and no success….I validated they were all correct multiple times. Is there another username other than “admin”, perhaps?
Thanks in advance!
Do you have the surfboard central app to access modem settings or if you are only using the modem GUI then you can login to the GUI by trying on different browsers or you can try on different device and also try clearing the browsing history, cookies and catches then try on Incognito browser. If all this doesn't help then you need to perform reset on the modem to login to the GUI using the default login credentials.
