how to connection Epson ET-2800 Printer on SBG8300
  • January 3, 2025
  • 83 views
I am having problems with new Printer Epson ET-8300 it will not connect to the slower WiFi.
any help?
Since you're having trouble connecting the printer to Wi-Fi, could you please let me know if you're trying to connect to the 2.4 GHz or 5 GHz network?
I recommend connecting the printer to the 2.4 GHz network. If the issue persists, try changing the security mode and reconnecting the printer.
To change the security mode, open a web browser and enter 192.168.0.1 in the address bar, then log in with your credentials.
Go to Gateway > Summary > Connections > Wi-Fi > Networks and select "Edit" for the 2.4 GHz network.
Finally, change the security mode to WPA/WPA2-PSK (TKIP/AES) and save the changes.
  • January 4, 2025
did you contact the printer manufacturer for help setting up their device?
