How to get Ring doorbell to work with Arris SBG8300
I can’t get my ring doorbell to work with my Arris SBG8300. It won’t connect at all to the network. I have tried to edit any of my router settings that seem like they might make a difference all to no avail.
If anyone has a clue on how to resolve, would be much appreciated.
To connect to “Ring Door Bell” make sure that you are able to see the 2.4GHz Wi-Fi Network names on the “Ring Door Bell App”.
Make sure it's connected well on the Wi-Fi 2.4GHz (check the password typed is correct). Also, let's change the security mode and Wi-Fi channels.
 To reach the security mode, log in to 192.168.0.1 with username: admin and password: password (if not customized). After logging on the 192.168.0.1 on the gateway page select “Wi-Fi”
and change the security mode from “WPA2-PSK (AES)Recommended”  to WPAWPA2-PSK(TKIP/AES ).
To change  Wi-Fi channels follow the below link:
If still unable to connect to “Ring Door Bell”  please contact them for more information
  • 2287 replies
  • October 8, 2023
did you contact ring?
Any other device having issues or just the ring?
