locked out when bridge mode toggled on SBG8300
  • September 10, 2024
  • 39 views
My slow speed internet lost wi if connection with devices in the house but high speed devices continued to remain connected after an internet and power outage. I tried reentering WiFi passwords on the slow devices no luck. I logged on to surfboard app and toggled bridge mode. Now all devices connect on to the WiFi signal in the house but are no longer connected to the internet. How do I reset modem/ router to factory settings without bridge mode. Surfboard internet location 192.168.0.1 no longer works.
Best answer by Netopia
Enabling bridged mode will turn the SBG8300 into a cable modem only.   That explains why the Wi-Fi devices got disconnected.  Try doing a hard reset by holding down the reset button for 20+ seconds.  You should see the default SSID again and get back into the settings.
Forum|alt.badge.img+30
  • Rockstar!
  • 274 replies
  • September 11, 2024
