Problem connecting devices to SBG8300
  • February 28, 2023
  • 138 views
I am totally not technology savvy. My problem is connecting 3 mini Blink cameras and 2 older laptops to the SBG8300. I reset the mini Blinks and they won’t recognize the 8300 unless I unplug the router for 10 seconds. Then they may or may not recognize it, and when they do I enter the wifi password. Then they disconnect a few minutes later. Same with the older laptops. I have 2 laptops, 2 phones, and smart TV that have successfully connected without problems. Any idea’s why these camera’s and older laptops don’t connect. The problem started immediately after setting up the 8300. Hopefully this makes sense.
  • February 28, 2023
Have you tried changing the 2.4ghz channels wireless channels? Try 1-6-11 for channels.
  • February 28, 2023
How do I change channels? Sorry for my ignorance. Thanks
  • February 28, 2023
You can find the manual here:
https://arris.my.salesforce-sites.com/consumers/ConsumerProductDetail?p=a0h0c00000P1guoAAB&c=SURFboard#panel3
it goes over logging into the router and changing settings on it.
