SBG8300 slow speed
  • October 25, 2024
  • 95 views
I upgraded my Comcast / Xfinity speed to 1000 GBPS but my speed test only shows up to 313MBPS. I tried and got the same result when tethered on WAN and on WIFI
I’ve tried restarting the modem and router both from Xfinity’s app and power cycling the modem / router. Still no change.
I called Comcast/Xfinity and they said I need to lease their latest router / modem for $15/month.
Is there no other way to get close to the 1 GBPS speed that I paid for?
Best answer by Netopia
The SBG8300 is probably stuck at your previous speed plan since the SBG8300 is not approved for Xfinity 1 Gbps plan.
  • October 25, 2024
You should get faster than those speeds.
How are you “tethered”? What device and what site are you testing with?
Did you try a factory reset/reinstall after the upgrade?
Sometimes a reset can force the new speed provisioning
  • October 26, 2024
yes I’ve done a factory reset after upgrading. and then I restarted it by using the comcast / xfinity app.
still the same 300 GBPS speed. nothing seems to change it
I tethered using a cable directly to the modem / router.
I used the xfinity and google and oomla speed tests. the xfinity one says 400 MBPS - the other two say 300 ish
If you are experiencing the slow speed, I would request you to check the cable signals and change the Wi-Fi channels.
Forum|alt.badge.img+30
  • Rockstar!
  • November 8, 2024
