WiFi Extender for SBG8300
  • April 17, 2025
  • 34 views
I have a SBG8300 on my first floor; the home is 3 floors/2700 sqft - the coverage inside the home is solid but if I step out to the deck the signal is very weak.
Want to add a Wi-Fi extender on the 3rd floor to improve connection/coverage but not sure what model/brand is compatible with my SBG8300.
Note: don’t think adding a mesh is possible, don’t have cable/Cat5 on third floor.
There are many reasons for weak Wi-Fi coverage:
  • If your gateway is in a corner or behind obstacles, it can limit the signal range. Positioning it higher up can help distribute the signal more evenly.
  • Devices like microwaves can interfere with Wi-Fi signals.
  • Walls, floors, and large objects can also block signals.
  • Too many devices connected to the network can slow down the Wi-Fi.
To improve your Wi-Fi coverage, try repositioning your router and reducing interference like positioning your gateway in an more centralized area
Mesh systems can provide better coverage and speeds. You can choose between two-pack or three-pack mesh units.
To set up, connect the first mesh unit directly to the modem as the main router. The other units will pair wirelessly with the main router. For the mesh unit on the third floor, you'll need an Ethernet cable.
For more features and details about our mesh systems, please visit our products page at https://www.surfboard.com/
