arris sbg6400 compatibility
is modem arris sbg6400 compatible for xfinity comcast 400mbps internet service?
Will it work? Sure. But it won’t be able to hit full 400mbps. its modem isn’t capable of that.
  • 2292 replies
  • January 3, 2023
No its not.
  • 2292 replies
  • January 3, 2023
  • January 10, 2023
Indeed. Plmeans.  Slow plus can’t handle tv YouTube loading v fast. Getting a 3.1 for up to 100$
Forum|alt.badge.img+30
  • Rockstar!
  • 274 replies
  • January 12, 2023
Some modems are capable but your internet provider won’t allow it on speed plan.  It’s always best to check your cable provider’s modem compatibility list  (http://mydeviceinfo.xfinity.com/).
  • 2292 replies
  • January 12, 2023
@arosso7o1 what one did you pickup?
