ARRIS SBG6700-AC - CAUSING STATIC ON MY AM RADIO
  • February 13, 2023
  • 16 views
I have an  Arris Surfboard SBG6700-AC  cable modem router.   I like to listen to AM talk shows when I am working  at my computer.  When I have my Arris turned on it creates heavy static noise on any AM radio playing in the house. On the other hand,  when I  try FM it plays without static.  I really need static free AM radio. Is there some type of adjustment I can do to my Arris?  Thank you.
  • 2277 replies
  • February 14, 2023
many devices can cause electrical interference. it probably is the modem/router device.
https://www.rsm.govt.nz/business-individuals/interference/radio-interference/sounds-like/#:~:text=Electrical%20interference&text=On%20AM%20and%20FM%20radios,many%20hundreds%20of%20metres%20away.
You could always try a frequency filter for the radio’s power cable.
