Model SBG6900-ac unable to reset wifi
Hi,
I have the Arris modem model: SBG6900-ac. I was having issue with WiFi connection and pressed the button in the back which ended up resetting the modem to factory setting. I own an apple MacBook computer and went to the IPS address: https//192.168.0.1 to reset the password. I used safari to load the IPS. It loaded the page. However, once I entered the wifi security key as password in the back, it does not load the page. The thumbnail does not load completely. Has anyone run into this issue and how did you overcome it? Customer service has not been of any help over the phone. Thank you
TechRep
Cable Modem Commandos
Forum|alt.badge.img+9
  • Cable Modem Commandos
  • 45 replies
  • April 11, 2023
Pls refer to this link to clear cookies and cache:
https://support.apple.com/guide/safari/manage-cookies-sfri11471/mac
if you get any message saying the website is not secure pls follow these steps:
http://arris.force.com/consumers/articles/General_FAQs/Alert-Message-for-Web-Manager-Access
Try to use a different browser or device if needed
  • 2277 replies
  • April 11, 2023
to load the “ips” what do you mean by that?
were you able to log into the router and go through setup after the reset?
Or are you still attempting to log into the router?
Because the log into the router password will be different than the wifi password.
