SBG7580-AC firmware update
  • January 9, 2024
  • 875 views
How can I update or find out if there is a firmware update for SBG7580-AC ?
 The Cable Operators (MSOs) have complete control of what cable modem/gateway hardware they will allow installed and the firmware it uses, this is because they own the coaxial cable that is connected to the ARRIS (SBG7580AC), because of that the Firmware updates are pushed by them, and any update needed as well. Any associated firmware updates are automatically deployed by the cable operator. This is not an ARRIS only implementation, but the required implementation of any cable device manufacturer.
  • January 12, 2024
Are you having an issue you think you need a update to fix?
