I have an SBG7580-AC wifi gateway running firmware {edit : personal information} (Xfinity is my ISP since a few months ago.) Does this firmware version correct the WPA2 security vunerabilities exploited by KRACK or do I need to acquire another wifi gateway model that supports WPA3?
SBG7580-AC WPA2 and KRACK
If you read the data sheet on KRACK, everything running wpa2 is affected. it isn’t an issue with the device but with wpa2.
But if you read enough, there’s issues with wpa3 too. So even upgrading won’t necessarily solve your issue if the person is smart/determined enough. Luckily, most people aren’t or those who are, have larger targets to go after. So for most users, its a non-issue.
But feel free to upgrade. If you’re worried about security, but a router separate from the modem. Modem/router combo devices rarely get updated and tend to have more security issues. If you have a router separate, you control the firmware and can update more frequently.
