Our G34 Keeps dropping sevice for our home.
  • 14 September 2023
  • 51 views
For the last two months our internet will randomly drop service and not come back unless we do a physical reset of the modem router. The longer this problem has been happening the more often we have to reset the router and hope our internet comes back. This is a huge inconvenience since both myself and my spouse work from home and rely on our internet connection to do our jobs. Help please.
Userlevel 4
Badge +38
Hello Cbroos
                      »  Is this happening on wifi only or even with direct connection?
                      »  Or is this on particular network or both 2.4 and 5G as well?
It is happening on both wifi and direct connection, and both networks 2.4 and 5G
Userlevel 4
Badge +38
Since you are experiencing intermittent internet connection with both wired and wireless connections, I suggest you check the cable signals to make sure all are in range.
To check the cable signals, find the link given below:
Also change the Wi-Fi channels, if all the signals are in range.
To change the Wi-Fi channels, follow the steps in the given link:
