I am having problems with my G34. I have it setup with the primary wifi as default name. I have the secondary wifi setup with a custom name. The guest wifi is not used. For some reason the modem will quit broadcasting on the secondary wifi. It will not even show up on the list of available networks.
If I go into the setup my setting are still there. Power cycle does not fix it. The only way to make it work again without a factory reset is to disable both the 5ghz and the 2.4ghz. Save the settings. Then go back in and enable both 5ghz and 2.4ghz. Then the modem will broadcast the ssid and work again, This happens every week to 10 days.
Any clues as to why this is happening?
Thanks
Bill
