G36 port forwarding for tivo
  • August 3, 2024
  • 24 views
I have the G36.  I also have TiVo.  I want to setup port forwarding for it.  I checked online and there’re about 9 ports to open/forward.  Do I have to find and put in all TiVo ip’s for each box and open a port for each one?  I’m confused on filling it out.  Example: internal start point, internal end point, external start point, external end port.  Some of the ports are 80, 443, 7387 and so on.  Can anyone give me an example on how to set it up based on the ports mentioned?  Thanks Joe p
Yes you can do port forwarding when the device is connected to the modem wifi network and you can do on the modem GUI or even on the surfboard central app. Since your have different port numbers to applied for the configuration you have to repeat the steps for every port numbers mentioned on the below article.
http://arris.force.com/consumers/articles/General_FAQs/G34-G36-Port-Forwarding-Setup
