Am I correct in assuming that my G36 assigns the WAN IP? I think my G36 changed the WAN IP when I reset to factory defaults. Is there a way to keep the same WAN IP? If I edit and manually enter the WAN IP will it work? I have other devices on the network that are dependent on the WAN IP. So, I want it to stay the same.
How can I ensure G36 always has the same WAN IP forever?
Best answer by Computer_Magus
The G36 is a router/modem - unless you run the G36 in Bridge mode then you would need a secondary router, BUT, that kind of defeats the purpose of the G36 router/modem.
Your ISP will lease the WAN then the G36 router will lease all the Intranet IP’s from .2 to .253. The default web access is Https://192.168.0.1 - DISREGARD the browser warning and proceed to the URL anyway. It is safe just some glitch from ARRIS that they haven’t resolved yet and don’t seem to care to resovle anytime soon. Going on past 9 months and still this issue persists…
So far I am okay with the hardware but give ARRIS a -----5 star on support.
