I recently switched my router, right now I'm working with the G34. I used to cast with my Google Chromecast with no issues but now that I changed my router, cast is not working. I haven't changed anything but my router. I also have a printer that is facing a similar issue but I'm not worried about that for the moment, I want a solution for my Chromecast
Issues connecting chromescast
Best answer by Anonymous
It’s definitely a hassle to change your router. You’re basically having to setup your entire ecosystem. First thing to make sure is that your devices are connected to your router. Chances are good that all your devices in the network might get a different IP address from the new router. You might need to setup your printer again on your PC. Hopefully someone else can chime in with Chromecast issue.
